When I push in my clutch and let it out slowly, right before it is all the way out it kinda pops or something. Its hard to explain. Its like the clutch pedal moves out nice and smooth until its just about all the way out then it kind feels funny right before its all the way out. I have these racing pedals on so I took off the clutch pedal because I just thought it was on loose and moving around but it still does it without the pedal on. It feels like the pedal is hinged almost. What is the problem here??
Check your clutch cable?
Racing pedals have springs/mini shocks in them. If you don’t tighten down REALLY well, you’ll have some play in them (even though they don’t slide). Also, you may want to make sure your not pegging you carpet and catching on it. Could also be a problem.
:shrug:
I’d go with the clutch cable as well, check to see if it’s attached right at the release lever and not hanging on something.
