Hey guys. I am having trouble finding out how exactly I adjust my clutch pedal freeplay. I have adjusted the pedal height, and arm movement to specs but I can push in my clutch pedal like 2 inches before I feel anything(2 inches of freeplay) . I looked at this diagram but I am baffled on which nut to adjust. Anyone got any good pics or videos on which I need to adjust?
Pop the hood
Look down on the passenger side of the car where the block number is.
There you will see the clutch cable.
On the cable at the transmission arm is a plastic nut the you can adjusted.
adjusted it and you should be good to go.
Don’t over tighten it,just tell you have a little under an inch of free play on the peddle.
[QUOTE=91_LS;2178202]Pop the hood
Don’t over tighten it,just tell you have a little under an inch of free play on the peddle.[/QUOTE]
Thanks man. In my Haynes it sais that plastic nut is for the arm freeplay. Damn Haynes manual. I will adjust it and see what happens.
Got it all adjusted. Used to grind occasionally going into gears 2,3,4,5th now it shifts awesome.:ohyeah:
