After i replaced my worn stock clutch, the pedal has some freeplay and it sucks. How can i fix this?
have you done a search?
Do you have a manual? Look for your clutch cable, which is attached to ur valve cover (just to hold it in place) with two clips. Follow this cable all the way to the tranny. by the tranny, you will see a plastic knob on it, and you will find threads on the cable. the knob is notched in to a plastic nub (you’ll know what I’m talking about when you see it) pull on the cable a bit to free up the knob, and you can turn the knob up or down the threads. This adjusts ur clutch.
HTH.
