Hey just wondering if any of u have teh same problem i hve with the clutch pedal. Well first of i have a 93 gs, everytime i clutch down to switch gears the clutch doesn’t come bac all the way up it gets stuck half way and not all the back up, i would have to use my feet to either tap it or pull it back up. Help please it’s annoyin the hell outta meeh. thanks
check your clutch cable. It may need to be replaced.
how would i go about checkin that???
Its the tension on the cable…it is too loose. Go to the adjusting nut down on the tranny and spin it down until it is snug. If that doesnt fix the problem then the cable is shot.
kool i’ll give that a try
Also check that the return spring on the back of the pedal arm is in place, mine worked its way loose and proceeded to bind about midway through the shift every time. Bought a new spring and viola, all better.
I had to replace my clutch cable when that happened. Yea its really annoying to tap the side of the pedal to get it to return.
