Clutch Problem HELP!!!
I’m stumped on this one.
Getting on the freeway I let go of third gear and the pedal feels wierd. I force it into 5th (really force it) and later get off freeway and coast to a stop since I couldnt get back into gear after I pulled it out of 5.
The pedal definately feels different and i can tighten up the clutch cable and get it to grind and almost engage. I cannot get the car into any gear.
What the hell happened?
the bracket holding the pedal looks normal so I think the problem has to be in the clutch.
Please tell me I’m wrong and it’s an easy fix.
Thank you.
Sound like a streched clutch cable to me. :think:
i would hope so, is common for a cable to stretch all at once and to this extent?
Drove perfectly up until i shifted.
:dunno:
well it hasent stretched all at once, its most likely happened over the years and you finnaly just hit the point where it wont work, try and change and see if it works if that dosent do it. it could possibly be the clutch PP.
:cross: for your sake that its the cable.
