after i was tightening the timingbelt, and putting the igniter and ignition coil into my b16a, also advanced the timing to 18 degrees
I test drove my car after and “Code 17” (Vehicle Speed Sensor) blinks on my ecu, i reset the ecu for about 10 secs and it stills doesnt go away. Also, my tach doesn’t display how fast im going.
How did I get Code 17, did the stuff that i did caused it, how?
I jumped the green/white wire and the brown wire together, when i advanced the timing. I don’t have another ecu to test the problem, so is there any other way.?
I’ve decided to reset the ecu again, for the rest of the night to see if there is any change before i go to work.
keep you posted
