code 20 and 22
hey i went to put in my vafc today, i had no cel codes when i went to do it, well i took out my ecu and pulled the 3 plugs on it (its an obd1 pr3 ecu) and noticed one of the 3 vtec wiring wires had come disconnected. I checked each one. A4, the vtec solenoid one, is still plugged in. D3, the knock sensor is still plugged in. But D6, the vtec pressure switch was not plugged in. So i plugged it into that one. However I got a check engine light. I jumped my ecu and it was throwing a code 20, (Electronic Load Detector), and a code 22 (VTEC System Malfunction). I have no clue why these would still be on. Can someone please help, thanks.
nvm i found it
