OK guys i have a problem with my B16 in my 91 teg. Ever sense i put on my VAFC i get a code 22 only when im rcing the car. I have the lowcam to hight cam at 4,800 RPMS the stock settign for the PR3 non OBD and high cam to low cam at 4,500. The problem is that when im racing and the motors stays in vtecfor to long i get a CEL code 22. This only hapens when i race on the high way. Does any one have a clue what it might. When i race out the whole the motor dosen’t do it. Only if the motor stays in VTEC for a long period of time.
Code 22 = Oil Pressure Switch
That would be attached to the VTEC solenoid valve.
Regards,
Oz
code 22 refers tot he whole VTEC system. I put in a new oil presure switch it still doing it.
You’ll have to download the VTEC supplement guide. Do a search for member XDeep. He has all the links for that stuff. I was going to type the whole troubleshooting procedure, but it’s better that you look into the manual instead.
Regards,
Oz
Thax i want to figure out whats wrong cause i hate CEL the motor still goes into VTEC cause of the VAFC the CEL is just anoying to see when i deside to race someone witch oly happens once in a blue moon.
Check your oil level when that happens (do it with the motor cold, don’t forget). It might just be an oil consumption issue.
Regards,
Oz
