Code 7 How to fix?
Okay so today I saw my check engine light come on…
so I pull the carpet and read the code off the ECU…
Im not sure if I read it correctly…
but it blinks 7 times in a row… then stops for a few seconds… then blinks another 7 in a row… so im guessing a code 7…
this is a 91 integra…so OBD0…
Code 7 - Throttle Angle listed in the teg tips…
how do I go about fixing this??
my guess is the throttle tilt sensor is messed up so i would check your connections to that.
should I replace the TPS sensor?
