i just bought some dropzone coilovers and im going to put them on tomorrow or something but the springs seem really little, they’re 6 1/4 inches plus the threaded sleeve is 4 inches. most coilovers are bigger arent they? is my ride going to be hellof bouncy or what?
naw, that is how sleeve-over coilovers are. they are short like that.
And I hope you are using aftermarket shocks with them?
if not…then yes they will be very bouncy and will blow your stock shocks out asap.
You need to get Koni Yellows if you dont want the ride to be really bouncy. Otherwise, get lowering springs instead with a sport shock. HTH.
Re: Coilover question
The actual springs themselves are only 6 1/4"?? I’m almost positive they are supposed to be standard 8" long 2.5" diameter coil springs.
