Cold mornings do not agree with Nobley. As soon as fall comes around, he becomes tempermental and screams when he’s woken up.
When reversing and the brakes are applied, a loud sound comes from the rear brakes. It isn’t a high pitched screeching brake sound. Instead, it’s a dull moan type sound. A friend of mine with a 92 gsr has the same problem and we’ve passed it off as there being condensation/moisture on the rotor and with the caliper making contact and with pressure being applied, the sound is produced.
The rear brake noise use to freak me out as the first time I heard it, I thought I backed over a small animal. I’ve since gotten use to but it still irks me come cold weather season (70-59 degrees here in coastal Southern California).
We’ve also run into another similar problem. On those cold mornings our springs squeek at every bump in the road.
So we have moaning breaks and squeeky springs. Do any other g2’s have the same problems? If so, do you know what the cause is?
Thanks in advance.
