im writing this thread cause ive searched and i became confused so i hoped someone could clear this up for me.
BEFORE I EXPLAIN I FIGURED ID ASK TO PLEASE REFRAIN FROM RESPONDING TO THIS THREAD BY SAYING HID’S ARE NOT MENT FOR JDM 1PC HEADLIGHTS CAUSE THEY BLIND PEOPLE ECT. I DONT CARE.
i noticed password JDM makes harnesses for 1piece headlights so you dont have to cut wires, which is would be perfect for me. Im looking to purchase a set of hid’s, i dont know which ones would work better 9004 or H4H bulbs. being that im a noob to both the HID scene and the JDM lights im confused, if i were to purchase HID bulbs, i dont need that wiring harness???becuase it replaced the bulb in the jdm headlights??? and if thats the case how does the fogs work do you still wire up those 3wires from the back or only the black one? … again i want this to be as easy and as clean of an install as possible. ugggghhh very confused lol…
id like some info on this topic before i go ahead and start buying stuff.
well your gonna haveto get an h4 or h4h hid bulb to fit into the jdm 1pcs and it your lights are stock now then they are 9004 bulbs. if you dont want to cut or modify anything (will cost the most) the get the h4h hid bulb with at 9004 to h4h plug and play from password. if you want to go the cheaper route, about 70 dollars cheaper, do the h4h to h4 conversion get the h4 bulb and make your own harness. takes maybe an hour to do with the right tools and that is with taking the front bumper off and installing the new lights.
sounds good but i dont know how to make that harness any tips would be dope…
also the h4h bulbs will fit right into the back of the jdm headlgiht??
also techone which is on this site selling HID bulbs told me that they would get me the H4H bulbs with the 9004 connector so supposedly i wont have to get a diffewrent harness for 220. that dont sound too bad to me- how would i wire this up to maintain the foglights.
Problem…if you get the h4h hid bulb for your jdm 1 pieces like me…you can only connect it to on light output…meaning only the low or high beam…now i dont know how to get both to work? im not trying to thread jack…but you will run into this problem…either that or i dont know what the hell im doin…either way…advice??
no thats fine, i want to know all the issues im going to encounter before doing this. how exactly did u wire it up, i personally dont mind loosing the high’s- some hid kits unless u buy the ones with low/high dont even have that option.
no i have the h4h kit…simply plug the two connectors on the hid bulb into your headlight harness. the black wire the to ground and the red wire to the low beam. everything else is plug and play on the ballast. those are the only 2 wires that hook up to ur car…
i just found out they have a low/high h4h hid bulb…which is about $100 more than my standard kit…and mine only is low…that sucks…
