Ok so this is my first Da with a/c and its hot outside. Trying to get it up and running. I need a little help though.
This is what I have and what I have done so far.
The ac system is already retrofitted as it was when I bought the car. What the car was missing was the ac tensioner pulley and the bracket. After trying to find it forever I finally got one for $25. Its already on now and I installed a new belt with it. I put a vacuum pump on it and it held at 30lbs for 10 minutes when I took it off. Today I bought some ester oil and three 12oz cans of freon. I let some of the oil go in before I started up the compressor and started adding freon. I am aware that if there isnt enough freon in the system the compressor will not kick on but at 60lbs I would expect something to happen. The compressor will not kick on. Now I am getting worried that the compressor is not good but I know that this still is not determined. At this point I am going to jump the compressor clutch relay but I have no idea where it is or which terminals I would need to jump to get the compressor to kick on. Any suggestions. Am I heading in the right direction?
Any help is appreciated. thanks
