whenever it rains or i wash my car, a small amount of condensation covers the clear area of my tail lights. is there an easy fix for this or do i have to replace the entire tail light?
silicone around the edge
If you look in Teg Tips it gives a detialed description of your problem, its under lighting. Good luck finding the gaskets that will correct the problem. Your local Acura dealer should be able to order them. I had the same problem, and its been a year of once a week washings and weather with no moisture problems.:werd:
