Hello, my car starts and runs fine until I turn it off, I will just crank but wont start. I took it to a gas station the other day, turned it off, filled it up, and it wouldnt start it would just crank and crank. I waited about an hour, tried it again, I got mad and hit the top of the dash a couple times while it was cranking over and it started to idle! it was a weird idle kind of like a low looping idle, I punched the gas the engine roared and it was suddenly idleing fine. I drove it straight home, parked it, tried to start it back up and cranked but wouldnt start. I have new, battery, distributor (re-built), plugs & wires, Ign. switch. I had bought and installed before i had this problem.
sounds like your main fuel relay… http://forums.g2ic.com/showthread.php?55129-MFR-fix-diy-main-fuel-relay-fix&highlight=main+relay
that link should help, but don’t be afraid to do more research.
yeah ill bet its the main relay , alot of times you can pull yours apart and look for dry solder joints and touch them up and presto your back on the road
