Conventional batteries not lasting as long?
I’ve noticed that over the years, conventional car batteries’ lives have been getting much shorter. I remember in the early 2000’s you could get a battery with a 5 year warranty. Now you’re lucky if you get 2 years. I’ve had to replaced the battery consistently every 2 years now, because they fail rather quickly, no matter what brand. This is on both of our Integras. Has anyone noticed this too?
I know I’m in a colder climate now which negatively affects their performance, but still. I think the warranty reduction itself states volumes.
You should look into sealed gel cell optima batteries.
Interesting. Not something I’d noticed but I’ve been using Optimas in my street cars for decades now with great success. Although I have heard that the quality on these have gone down (I just haven’t experienced it). I wasn’t too familiar with battery warranties previously but I just looked now and autozone sells a ton of 3yr and I see one 5yr (didn’t check specific fitment for G2’s though). Personally I refuse to run anything but sealed batteries anymore, I just don’t see the point in not doing so.
Buy one from Costco. They have a 3 year warranty with a return process that is basically a no questions asked thing. Just bring it in every 2 years and 11 months and say it won’t hold a charge anymore and walk out with a fresh one.
walmart and call it a day
I would opt to Optima, I bought them for my previous cars and loved it! its pricey up front but worth the cost, if that’s a concern.
When i worked for pepboys along time ago as mechanic, i did replace numerous batteries that were towed into the shop that was 2 years old or less. Of course it was covered under pepboys warranty but not the tow. So yeah i do agree. Todays batteries seem to be designed to go dead right after warranty or before if your lucky…
delete
Thanks for the input everyone!
I actually have a AGM Optima battery and still going strong after 7 years, no I say that and it I’ll die in a few days or so. I better keep my fingers crossed. The battery got discharged to like 4 volts a few years ago (ouch) so I took it to an AGM specialist and he was able to bring it back to life within a day. Since I don’t drive the teg that much anymore (reason why it got discharged) he recommended that i buy a 1-2 amp battery maintainer which I did, now it’s inside my home and no worries cause it’s a sealed unit plus it stays a lot cleaner inside, that is till I start using it again. All in all the battery maintainer was well worth the investment cause I can bring it back as long as it doesn’t go below ten volts, the maintainer is a 1.5 amps so it’s gonna take a while to charge it but that’s how your supposed to charge agm batteries, a slow charge rather than using those quick battery chargers that they use in conventional batteries. You certainly get your money’s worth and some more with agm batteries.
I have had a yellow top fail early, but it was more than likely due to self discharge and poor maintenance. They are awfully heavy, but good batteries. I bought an icharger battery charger a while back to handle my higher voltage lithium batteries, and found out that it can do wonders for all types of batteries. I have saved a handful of batteries from being tossed by using the icharger on them first. It is a solid state charger that datalogs, can charge and discharge all the battery types I could see myself owning, and allows you to change charging modes, cutoff cell voltages, and charge rates. I replaced a 6 year old battery in my truck because it was going bad, but then I ran it for a couple cycles on the charger where I brought it up to a higher cell voltage, and its been in my integra now for the last year and a half working fine. That said, when I get time to work out a basic integrated BMS for a 3/4s battery, then I am going to build a lightweight lithium battery for my integra.
That sounds like quite a project! Keep us posted.
