Converting 2G Teg into Type R Teg?
Making a 2nd generation teg apperance look just like a Type R Teg is possible, am I right? They look the same body wise.
The g2 and g3 integra’s are very different as far as shape goes. Our headlights are similar to the JDM Type R, but that is about it, the interior is different, the bolt pattern for the wheels, the front and rear bumper styples.
:slight_smile:
There’s a Kid here, that had a ITR sticker on a 92 Teg, and SIR Sticker below the mirror, on the driver side door. The ITR came out in 1997 I believe.
how about engine wise? the engine should bolt on, will the tranny bolt on too?
G2Guru is the guy to talk to about putting an ITR drivetrain in a G2. Check out his car on the turbo page
Yes the b18c5 will bolt in. The Tranny will not work, because we have cable, and the itr is hydraulic. You can use a Jdm S1 tranny it has the same gear ratios as a 97 ITR. Also depending on what year your integra could mean you have OBD or non OBD.
