I have a 92 teg with a gsr swap, I noticed the middle hose is leaking pretty good. The one that connects under the vtec solenoid, and by the coolant temp sensor. Are there aftermarket ones? I see ones for upper and lower, but I need to get the middle one fixed asap!! Are there aftermarket ones or is that just bulk hose?
Just buy some bulk coolant hose and be done with it.
If it’s an OEM bent hose (thermostat housing to intake manifold) get the OEM one because bulk hose will not make that bend.
If you’re talking about the one from the firewall (heater core to cylinder head), that one can be bulk hose as it is pretty straight… but make sure it is the right diameter of hose that has the nylon webbing.
yeah it is just the one from the firewall to the head, thanks
