cooling fan diagnosis w/ removal of a/c harness
Hey my cooling fan is not working, and the a/c harness has been removed from the car, since no a/c components are installed any longer. So my question is, is the a/c harness necessary for cooling fan operation. From the crappy wiring diagram i have it is hard to tell if relay is on a/c harness. The plugs for cooling fan are on the main harness for headlights, so i dont see need for a/c harness. Hopefully someone has experienced this, Any help would be great, Thanks.
You dont need the a/c harness for the cooling fan to work the green plug fron the fan plugs in to a white plug off the harness if you do not use the a/c harness
ok, i see, i will try that thanks
