Just a quick question concerning the fan switch and/or cooling system… But first, a slight background.
Before I completed my motor swap, my Integra was sitting for nearly 3 years.
Since my swap has been finished and I’ve been doing the break-in period, the cooling fan(s) have never come on… Yet the temp gauge always has been steady at operating temperature, sitting just shy of the half-way mark on the gauge. Even during the summer when driving it, never once did it get hot.
I figured it was just coincidence that I never saw the fans on, and left it at that.
A few weeks ago when on the dyno, after about three pulls, it got hot… Above half way. Naturally, we threw the big floor-fan in front of it and it fell right down to operating temperature.
The next day I disconnected the harness from the thermostat housing fan switch, and jumped the plug with a piece of wire… The fan instantly kicked on.
I’ve since gotten a BuddyClub fan switch, but since the car is in storage I’ve yet to replace it.
On to the main questions…
By jumping the harness connector, this is simulating the fan switch “closing” the circuit, correct? So I am safe to assume that all the fan relays etc are functioning correctly?
when doing the swap I removed the A/C system, pump, condenser, etc… Would have that have any affect on how the fan switch and cooling fan will operate?
I realise I could look this up in the wiring schematic… but for one I’m actually out of town at the moment, and two, I’m an idiot when it comes to electrical and wiring.
Bottom line, I have the new fan switch that I’m hoping will solve my cooling fan issue… Is there anything else I should be looking at as far as the culprit?
The car is an OBD1 1993 LS… running on a chipped/tuned P28 ecu.
Thanks for any help you folks can offer!
