Cooling fans come on EVERY TIME I shut off my car?
Every time I shut off my gsr, the cooling fan comes on and runs for about 10 mins. Is this normal? Even if its a normal day, shit even if its cold! the temp gauge works fine… Maybe I just dont remember because my las ls didnt have ac, therefore didnt have this fan.
my horizon car used to do this too… someone told me it was the fan module thingy under the dash, but i was too lazy to get under it and change it.
Cool- thanks Daniel, Ill look into it. Im still seriously considering the si, but I came up on something today… its a 98 white gsr- Got stolen, took off the suspension, f/r lights, f seats, and distributor. Clean title, he wants 4500, but its in the tow yard in sac, and he lives in san fran. Im meeting him, and Im gonna lowball with 3k cash. If I get it, great deal- If not then o well right
yea is the module it was happening to my teg i just took the entire fan out!. phuckit. i t was a thread on here that told you how to fix it . i am not to sure where it is or where it at.
Cooling Fan
My car does the same thing. Only once in a while but it is always after the key is rolled off. Fan will run about 10-15min. Is the A/C fan or the cooling fan running? I don’t want to unplug it if it going to cause it to run hot. Any info you know on this I would appreciate it. Thanks.
Mine was doing the same thing. I replaced the fan switch/module under the dash and problem is fixed. Also, it seems to run smoother. Like when I’m sitting at a light with my air on, my whole car isn’t vibrating and rattling. The part was abou $150 and install was around $80.
I guess this is a Teg thing,
The fans on my CB7 will not turn on as often as my DB1. I guess it must be based on design as the teg’s front end appears to be more air restrictive than the Accord.
