Copper head gasket
okay so im going to have to do a head gasket on my car its a b18a1. has anyone used a copper headgasket before? do teh torque specs change due to the cahnge in material?
Just get an OEM gasket from the dealer. The OEM gasket works more than adequately, so why risk using anything else?
Only time a copper gasket is worth it is when you need a custom bore or something along those lines…
Otherwise as Colin said, a MLS OEM Honda gasket all the way.
[QUOTE=unified112;2295607]Only time a copper gasket is worth it is when you need a custom bore or something along those lines…
Otherwise as Colin said, a MLS OEM Honda gasket all the way.[/QUOTE]
okay, a friend jsut told me about it… and i wanted some more info on it thanks guys!
http://honda-tech.com/showthread.php?t=2714776
It’s one of those cases where, the Honda gasket is perfect… why mess with a good thing and risk reliability by running something else?
If you need a custom bore, Golden Eagle make oversized units… they’re very similar to OEM.
