I have no problem starting the car, kicks over every time.
-Exhaust lightly pops and gurgles when i got over 2500 rpms
-Car lightly jerks while accelerating in lower gears
-When warm it idles strange, not fluctuating up and down at a constant rhythm, but kind of chills at 700, then randomly raises and dips like its losing power
How severe dos this sound?
I would like to add my check engine light randomly came on the other day, i turned off the car and hasnt came on since.
If your worried about the belt you should do a visual inspection as well as a deflection test but it sound more like a sensor or timing issue, I would take the time to clean them out. Do you have any vacuum leaks? Try adjusting your timing back to 14 before TDC with the distributor.
Thanks for the suggestions i will get at that in the morning!
Well i recently bought this car, the guy before me had just taken it to the mechanic before i bought it. At the shop they replaced the alternator, battery and drive belt. At the bottom of the page from the mechanic it says they recommend a timing belt kit at $500
Awesome thanks for the help, I am handson with cars but im a noob lol, ill definitely be searching some youtube tutorials lmao hopefully i dont mess anything up
