I am now currently rebuling the short block of my engine, and i was wonderin what anyone thinks of CP Pistons, my engine is not Vtec, and at this time not boosted, so i am lookin for a higher compression. Is higher compression the way to go wit a rebulit b18a engine, (11:6:1) compression. if anyone can get me a good compression ratio for an all motor b18a engine, and the company details.
CP pistons, based on what I gather when I was piston shopping is 1 of the best piston to get. They however cost me $475, if higher compression is what you are looking for and plan on retaining a stock bore then ITR b16 or even CTR pistons are the way to go. The CTR piston will yield the highest compression, but will require a little machining to fit them on LS rods. B16a would be my choice for direct fit and good compression and you can get them at a reasonable price if you shop around. Good luck
