pretty sure it is not, just making sure - thanks.
NO, just a beotch to get off…there is a special tool
BIG ASS AIR GUN
No 3/4" drive gun will take some of them hard ones off. You need 1"…
thanks… just ordered that moroso tool so I should have no probs hopefully.
took me 2 days before I rented a inpact wrench to take it off
I’ve had to use my Moroso tool a few times already. It works – you just need a BIG-ASS’ed extension on your breaker bar. I had to use a 4ft-pipe (3-ton jack handle).
Heat is the answer get that bolt cherry red then put an impact on it . i did it!!!
Snap-On guy LOANED me a ~700ft-lb impact wrench. That, combined with the Snap-On pulley-holder took about 45 seconds to get that bolt out. If you can talk your local dealer into it, it’s the way to go.
