ever considered, no offense but, your driving skill. i know it doesn’t take much skill to drive in a straight line, but shit i’ve seen dumb ass people such as my former friend wreck goin straight, in a stock 01 gsr. and he blamed it on the road which was bull shit cuz i raced with his car and the road seemed fine to me.
[QUOTE=Mk1shitrocket;1907625]Think its not breathing as well as it should? Think that a header and bigger exhaust would help quite a bit?
Thanks[/QUOTE]
I Would say yes. It will flow more freely and since you are using NOS you should see a big difference.
Focus on getting all the power to the ground through drive train and suspension first if you want a bigger difference.
Clutch/flywheel, stickier tires, tire psi, keeping traction over front wheels will note you better times. No point in having all that power if you can’t get it to the ground properly.
Adjust timing and run correct heat range spark plugs when using nitrous.
Thanks. I am running bkr7e’s and 2deg retarded. Tonight Im going to start with a compresion and a leak down to make sure nothing got harmed last night and to see if my problem pops up…
Thanks
Well did my compression test and came up with:
1: 187
2: 187
3: 190
4: 195
My cluster says 218k which matches carfax so im begining to think that it may have a rebuild or a newer engine…
Anyways I ordered a Megan header tonight so when that comes in I will get the rest of my exhaust done. Until then I have to figure out what muffler I want…
knock down that 60 footer, and you’ll be in the 15’s easily. it’ll take a lot of practice, but you can get that 60ft time down into the 2.1-2.2’s on street tires.
he said it. if your running ac and ps take the belts of and you’'ll feel the difference .and turn your heater on it at always made a difference to me.
Also what about the track surface, was it a decent track? Temperature out side? What condition is your clutch in?
I know from Feb. to July my car slowed down about .5-1.0 seconds. Well my clutch was going out too
just got bak from edgewater tonight, and with a bone stock ls motor with working cold ac and ps and the long ys1 trans i had:
r/t .345
60’ 2.487
1/4 16.182 at 86.03 mph
mods include skunk2 coilovers and shocks, and 3 out of 4 window welded motor mounts, probably could’ve ran a BIT better but i wasn’t trying too hard, it was out of 2 runs lol. 1st run was:
r/t .203
60’ 2.565
1/4 16.200 at 84.75, i hit rev limiter in 3rd near the end cuz i figured i would cross the line beforehand but i was wrong, oh well
Hey thanks for the input… That gives me a clue that something is wrong… When I get back into town I am going to install the header and take it to the exhaust shop to have the complete exhaust done. Then I will do some more tuning and will be back at the track…
