i’m dripping oil…i’m not sure where it is coming from…it seems to be spread around the bottom of the engine under the car…and it dripps…i just changed my oil and the problem still occurs…i was taking off my chikara headers and putting on my stock ones for now(DC 4-1’s comn’) thats when i noticed that it was kinda mess down there…anything i could do to try to make the leak stop…nothing big or expensive because i’m gettn’ rid of the engine this summer…anything would help…
later,
Dan:p
Check around your block (at the seal) under the valvecover and see if there are black streaks but if none then check your oilpan plug/pan itself.
sounds like it could be the oil pan gasket…
oil drip…
you might check ur oil pressure switch. i know on my car, i was dripping oil, i changed my oil and it was still coming out, messed up my driveway, but i had it looked at, and it was an oil pressure switch. i thought i was the oil pan gasket, or the plug, but i lucked out and it wasn’t.
where is the oil pressure switch…do i need to replace it or can i just do somting to fix it…thanx a lot for the help…
later,
Dan:p
later,
Dan:p
Look at your Oil filter, the oil pressure switch is just to the left of it.
Regards,
Oz
