When I launch the car from first, I hear a creaking noise from the right front side. I checked under the car and it seemed as If there wasn’t any broken suspension pieces. Could it be a bad shock??? I got a 91 gs with 87k on it and I think i’ts starting to take a ****!!!Help
Do you have a camber kit?
if you do, relube it.
Is it a squeeking noise? or a click metal type noise?
If it squeeks and u have an polyurethane bushings…then EDA9 is right about correct lubing…
but if its the other sound, most of the time its the CV joints on ur axles…check to see if ur CV boots are okay and not ripped…
