Hi,
I have Goodridge stainless steel brake lines and they really improve the brake feel, but I have a question. When you are servicing the calipers, you normally put a slight crimp in the rubber brake lines so you don’t leak a ton of brake fluid all over the place. Is this even possible with stainless steel lines? I’m sure I could use a vice-grips to increase the pressure, but I think this might damage them or not work at all.
What does everyone else use? It’s not just the fact that I’m losing expensive brake fluid (ATE Super Blue), but that much brake fluid pouring out gets everywhere.
Any help much appreciated
eris
