Cruise control and windshield wipers both quit, ICM?
My wipers will not turn on and the cruise control refuses to “set.” I feel like these are related, since they happened at the same time, Do I have a faulty ICM ? Thanks for helping.
Check your fuses?
Does the cruise control light in the button turn on? What about on the gauge cluster?
Do your wipers work with the mist function?
Also I would recommend you look at this post http://forums.g2ic.com/showthread.php?124875-Where-is-ICU&highlight=Cruise+Contorl
and FYI it’s an ICU not an ICM
icu only controls int. wipers, i believe
check your brake lights, as cruise is usually integrated into that circuit
Ditto the above^^^ the ICU only controls interm. wipers and has nothingto do with CC. 94
