Cruise Control pinout? **Searched**
Ok, does anyone know what each wire does on the cruise control switch? I need the main two wires that actually turn the cruise control on and off. Basically the wires that matter when the switch is turned on. There are 6 wires out of the back of the switch as well. Any help will be appreciated! TIA
I apologize if I missed it while searching…
:slight_smile: This subject has been covered rather well in the electrical forum. I’m real sure FCM has listed the wire colors and location a couple of times. Try searching there.:read:
Thanks, I found it. FCM actually didn’t know much about the switch. It was a member by the name of “Tom”, I think unregistered, that had the answer I needed. I found it though, thanks.
Glad to help. Now, fix it and enjoy.:werd:
