cruise control problem
well here it goes. setting cruise control you could usually set it going about 40mph already. I’ve press the cruise button light and everything comes on but still wont set. I go on the freeway and try it at a faster speed and still nothing happeneds. I thought it would be the cruise control module in the front, so i changed it still doesn’t set. Now I’m wondering if there is a fuse or a relay somewhere I could check. Anybody out there wit the same problem, please help. Thanks.:search: :gotrice:
can anyone help
Ask the moderator to transfer this to the electrical section, as most of what the problem is/are will be electrical. If I remember correctly, there are only multimeter checks till you get to the black box on the fender which does have mechanical stuff to pull the throttle. If you search the FAQs/TegTips there are a number of threads that state which fuses to check.
:ok:
By the way, I do believe you have a town nearby.
:rules:
