Is there any way of modifying my Ctr SRS MOMO steering wheel into a da9? Also I’m new so idk how to input pictures .-. Any info helps thanks
You would need to either modify the splined section of the steering wheel or swap steering columns with a column with the same spline size/pattern as your wheel. I would suggest trying a steering column swap from a 96-00 civic into a DA at the junkyard first to see what problems arise and if it looks like it would work buy the civic column. If not at least you’d be out no money, just time.
