Curious........
Ok, here is the deal.
94+ integras have the electronic speedo…
90-93 have the cable going to the tranny…
If I were to wire up a 94 integra harness…
( I have a complete 94 integra vtec harness. headlights to taillihgts and all the fuse boxes, relays, etc…)
and use the P72 ECM, then what the hell do I do with the speed sensor?
My cluster has the cable for the speedo, would it still read my speed??
Would it throw a speed sensor code because of the electronic speed sensor in the 94+??
OR say fawk it and try to fit the 94 GSR guage cluster in my dash?
OR is it worth it, to “chip” the 92 GSR ECM for 94+ values, and run it that way???
( because it has the same cable going to the tranny…)
This has been giving me a headache…seems so simple, yet I am making it so hard…:frowning:
Any help or suggestions…?
Thanks…
there is one thing i’m unsure of. Why the hell would you want to swap a 94+ wiring harness into your car? I’m not sure what the purpose of that is… what exactly are you trying to achieve?
I don’t see any good reason to put that harness in your car. For one thing its obd1, which means you’ll need a new distributor, injectors and maybe some other engine compartment things. And there are probably some other things that just won’t be able to wire up correctly without a lot of modifications.
oh, and that p72 won’t work with your b16a. The p72 is for the b18c1 which has dual intake manifold runners, your b16a intake manifold only has a single set of runners. So, for the p72 to work on your engine you’d need to have it chipped to have the dual butterfly program removed.
First off what year car do you have and what ecu do you have right now?
you should be able to connect a 94-95 ecu to your 92-93 wihtout a problem.
Originally posted by teg2nv
[B]First off what year car do you have and what ecu do you have right now?
you should be able to connect a 94-95 ecu to your 92-93 wihtout a problem. [/B]
his car is a 90… or so it says in his profile.
Ok, I should have said, NOT for my current car…
I have a standalone in my current integra…
I have a 1990 shell ( no wires ), and I got the 94+ harness for free…
I am going to put in a 94+ B18C1 into it anyway, so I will have all the parts necessary.
Just wondering about the speed sensor stuff, as I have EVERYTHING else wired and ready to go…
I thought that with the 94 ECM that you would have to run the electronic speedo, without throwing a speed sensor code, and have the speedo still work…??
