Is there anybody doing a current or existing K swap in their DA?
I am still getting parts all togetherright now tho. Going with k24a1 block going to bore out to 89mm 12.5:1 comp z3 head with z3 tranny.
That’s great! Let me know if you need any help with anything or sourcing parts. If you were closer, I’d turn wrenches with you.
I have read ur on k20a.org Anthony looks good. All I have is block so far. Got it tore down so far still getting parts for mine
Hi Anthony, i’ve read over your build as well. it looks great. Sorry I wasn’t able to get a mid pipe made in time for your ktuned header. It’s finally done. It made great mid range power.
What header and exhaust, Radiator, mounts, etc are you planning to go with?
i am running a ktuned ram hearder, 2.5 to 3" offset adapter, thermal R&d 3’’ turbo back, rsx type s aluminum 4 core rad, hybird racing/ innovative mounts 75a,
for now it still street able but i am build it for track racing,
every da i’ve seen with a K has terrible ground clearance with the sump. is there any way around this?
