Does anything look wrong in this picture? the two on the left are the front and the two on the right are the rear. Both shocks are the same size, the springs are different and the mounting pieces are different. I’m thinking the springs should just be switched around. Any input? These are D2 RS coilovers, without the camber plates at the top.
I’m not quite sure but I do think those springs are on backwards.
Yes when i look at it , they to look like there backwards
check the spring rates (should be imprinted on the springs) front should pretty much always be stiffer. for example 10k front 8k rear is a typical set people run as far as im concerned
