da front fork
i need a favor from someone. i need to know the diameter of the front fork. i need to compare size and shape to the jdm version. i know there is a differance because supposedly, the dc shocks are supposed to work with da forks. well i have da forks and dc shocks and they do not work together. the dc shock is much fatter than the diameter of the da fork and i would like to see if the usdm and jdm models are different. if so, then i need to buy a usdm set of forks…
Im pretty sure dc shocks dont work on da forks, hence when people swap dc suspension over they use eg/dc forks
Dc shocks do not work with Da forks, that’s why you have to use dc forks if putting dc shocks on a Da
The dc fork on my car doesn’t allow nearly enough clearance for the axle. I was thinking that maybe something was different from the jdm to usdm model.
