Hey guys fixing to do a rhd drive conversion on my 92 integra and im going to be using the obd0 engine harness from the front clip but im going to stay obd1 anyone got any ideas, i have a few ideas, also anyone that done a conversion is there any other wiring problems that i am going to run into on the project?
lol anyone?
welcome to hell buddy…just kiddin, it’s not that bad. i am almost completely done with my swap as well. i took the ENTIRE harness out of my left hand drive 91 LS, flipped it over, lengthened a few wires, and installed it back into the RHD donor chassis. alot of work my friend. as far as splicing two different OBD harnesses together, i dont think it will work. i may be mistaken, you could just use your existing 92 engine harness , no?
i just finish my rhd all u have to do is us the complete body harnes that comes with your clip and use the obd 0 engine harness and just get the conversoin to obd1 really easy to do
yep you can do what they both said as i flipped my harness an used my u.s. one but now i am going to redo my car with the jdm one an wire my whole car to the jdm specs an think i will do a obdo to obd1 jumper as well…on a side note we should start a rhd thread as we have a car color thread blk,red,sliver an so on
post pics of your rhd build
HERE IS MINE
Make a proper thread in General Discussion then.
This is a help thread that is 2 years old (I’m sure the OP has figured it out by now) and not a place for posting RHD builds. :roll:
anyone do a rhd write up? in beginning stages of my own conversion, but all pieces from clip disassembled prior to purchase. the sally i bought from didnt wanna finish it.
did you use a rhd engine harness or convert your usdm harness to fit? ended up getting obd1 rhd chassis harness and need to figure out engine harness. can not locate da6 wiring harness
