Well I’ve owned a 90DA and I am currently looking at getting a 92DB. Looking to see what all can be converted over to the DB. Also what exhaust systems and suspension parts may be available for it. Any info would be greatly appreciated. Thanks ahead of time guys.
Nobody has any input on this?
whole suspension can be swapped, springs, struts, upper lower control arms/camber kits, etc etc. I think, not 100% sure, but just the axle back only from the exhaust. Theres probably more, but that gives you an idea.
Do you think the rest of the exhaust would work with extensions welded into the front side of it? I know the length is the biggest problem being a longer car. But I’d hate to scrap a good hks hi power.
make the b pipe longer an you should be ok
Thats what I was thinking too. Anyone know of any trunk triangulation set ups like there are for the DA?
All the front end stuff is the exact same also correct? Fenders, hood, headlights, bumper?
everything from the firewall forward is the same
exactly…all of the suspension is all the same too. also you would have to use the header/exhaust manifold from the db1 since its obd1. o2 sensor is in a different location as well as the tubing. 92 is 4-2-1 and the obd0 is 4-1 w/ the bung on the top half.
Interior is only the same from the center console, e brake, armrest etc< dash forward & front seats. The rest of it is db1 specific
Have an adapter pipe made for the db1 btwn the cat and hks hi power. bolt it right on. db1 is only 2" longer on the wheel base… axle back is the same
hope this helps. g/l!
