okay i have a 91 integra slammed on ff type 1 the jack point are a half inch off the ground, i have them bottomed out the piece that screw up and down. but the front is higher then the back the back is tuckin wheel (not tire) by like 1/2 inch and i want that in the front but i cant. and solutions on how to fix this
Extended top-hats, if they make them for that suspension setup.
Otherwise, you’ll need a different shock all together in the front. If it can’t be adjusted lower, it can’t be adjusted lower.
I’d raise the rear to give the front/rear rake you want and call it a day.
In order to go lower after messing with the preload u need to remove 2 of the 3 rings they come with, n it will allow u to go a bit lower. However the rear will always be able to tuck more than the front. Who knows why, that’s just how function form made them.
Do the extended tophats, dont mess with the preload.
