My front has a 3 finger gap, and the rear is tucked… wtf?!
try seeing if the springs are on backwards.you got the front springs in the rear, and the rear springs on the front. just switch them.
i already did that… and the front was dropped and the rear was hella high.
Thats how it should be then…its a nosedown drop…hence…2.5" front, 2.25" rear.
Stew ![]()
but the stiff spring is in the front right now? wtf?! when i had it the other way around it was HELLA high in the rear…and dumped in the front.
which are which?
these are 94+ integ springs… so i dont think it should matter.
I’d say the bottom ones are the front top one is the rear. but can’t be positive
there should be writing on them…should be #'s then either an F or an R
F=front
R=rear
Originally posted by Gigarange
[B]I’d say the bottom ones are the front top one is the rear. but can’t be positive
F=front
R=rear [/B]
thats what i have right now…
Actually, it looks like the bottom ones are the rears (looks like they are narrower) … and if you are running G3 springs, it is possible that it has a different weighting, cuz the G3 is a heavier car. The wider, taller springs should go in the front.
Originally posted by Sir rev alot
[B]^^^
these are 94+ integ springs… so i dont think it should matter. [/B]
Ummm it does matter, g2 springs are different lengths than g3
[B]^^^
actually it will matter. 94+ integra springs have different rates and drops. if you wanna get rid of that 3 finger gap in the front, get some g2 springs and the gaps will even out more. thats whats gonna happen if you put springs from a different car on, uneven gaps, ride will probably be worse too.
this will be there fate.
Can you say…let them settle in first?
3finger gap will not settle.
Change the springs. I did the same thing w the same brand and even the same year. Same problem. Bought some Neuspeed for the g2 the were a perfect drop.
I got a set of G2 sprint springs thatll work for ya…just sell those 94+ springs to somebody for whatever and I’ll sell u mines for $40 shipped…
Thanh
dam, i had sprints that gave me a 2.5" 2.25" drop as advertised (well i didn’t measure, but it was close)… from the pic, it look like you have two rear springs. did you buy them used? btw sprints don’t say “F” and “R” the shorter spring is the front…
Yeah i got sprint on mine and they are all good…
asian buddha I emailed you.
Sir rev alot-Hey bro, email me at vietbubbletea@hotmail.com…I dont check nailynn27@hotmail.com as much anymore.
Thanh
