Dash Lights and Tail Light out when Popping the Trunk
Hi… had this problem a while - just narrowed it down. Wondering if anyone has seen this or has some advice.
I recently replaced the ICU and the blinker/washer sticks on the steering column…
Now… when I pop the trunk, fuse 11 blows under the dash fuse box. Lose the dashboard lights (just the back lights I think) and my tail lights dont work.
I also disconnected all tail lights today and it still blew.
I’ve disconnected the green wire to the latch for now and everything works. Could it be a bad trunk latch?
When I dismount the latch from the trunk and ‘pop’ it - the whole assembly is charged as I can see and hear sparking from the pull cable… also- was heating up. Then as soon as it touched a ground, the fuse blew.
MM&Y of car and trim level would help. 94
It is a 91 LS Special hatchback. I’ve owned this car since 1994… all stock and in very good condition with 280,000 miles!
That is strange, the only thing at the hatch will be latch switch, it is a grounding switch, it supplies a ground to the “CARGO LIGHT” and the “HATCH OPEN WARNING LIGHT” in the cluster, the cargo light is on fuse 14, same as dome and front map lights, [if you have them], the hatch open warning light is on fuse 23.
Fuse 11 is the dash lights and running lights, [tail lights] fuse.
The only way I can see this happening is if the lead from the latch switch, [green/black] is shorting to the tail light wiring, red/black.
To test, remove cargo light bulb, keep ign. switch off, unplug the green/black from the latch switch, turn on the running lights, test the green/black for power, if you have power at the green/black when the park lights are on, then there is a short between the green/black and a red/black.
If you leave the cargo light bulb in place ot if the ign. is on you will read 12V+, [power] on the green/black, it is the power on the other side of the cargo bulb/hatch warning bulb 94
Thanks - I did this before but now your email confirmed.
I did remove the light bulb as well as the entire socket. And I do read 12Vs at the green/black wire that goes to the latch when I put the headlight switch on (first spot).
Also - there is a delay when I turn my headlights on - the circuit that blows the furse (dash lights and tail lights) does not turn on immediately. There is a few second delay.
I do have aftermarket tail lights (and headlights) - installed a few years ago. But, I completely disconnected those a few days ago and still blew a fuse 11.
I think I’ll have to disconnect the J/Cs at the right side of the trunk and then ground the green/black wire to see it still blows the fuse? This will tell me if it is in the trunk or before the trunk right?
I’m using a Haynes manual and don’t particularly like their schematics.
Parts replaced recently last 4 months or so:
ICU
Turn signal stick/windshield wiper stick assy
Stereo
If the green/black is not plugged into the latch, or hatch is closed the fuse should not blow untill you ground the green/black, or if plugged into the latch, open the hatch, [which grounds the green/black]. 94
OK - so I looked around the trunk wiring a bit… don’t see anything obvious.
Note for these measurements the cargo bulg is removed (whole assembly removed).
I removed Fuse 14 then measured green/black to ground with headlights to park and key off. = 12V
Then removed Fuse 11 then measured green/black to ground with headlights to park and key off = 0V
Turn headlights switch off - no voltage (duh)
Jumper wires for cargo light with headlight switch off - tail lights come on - door chime goes on - 12 volts at green/black
Remove fuse 11 - same as previous
install fuse 11 remove fuse 14 - everything out and no voltage.
ok - so somewhere the wires from fuse 14 are shorted to fuse 11?? now… WHERE?? Behind the fuse panel most likely?
You can not have a short between two power leads, they may be “crossed”.
With fuse 14 pulled, [interior lights, dome, map, glove box and trunk/hatch cargo lights] pulled you should not read power, [12V+] on the green/black, if you do it can only be from a short between the green/black, [a ground trigger/supply] and a red/black, [park/tail lights].
This is confirmed because fuse 11, [park/tail light fuse] blows when you open the hatch, turning the green/black into a ground.
That short can be any place the green/black is close to any red/black lead, both leads run down the drivers side of the car, the green/black runs up to the cluster, [trunk/hatch open warning light]. 94
btw - issue was bent pins on blue connector at fuse panel… guess it happened after replacing ICU.
