Came across this doing the foglight switch mod to my 90 rs.
DIRECTIONS!!!
BEFORE finishing up the foglight mod grab the red/yel wire that is not used anymore (the one going into the dash), and hook it back up to where it used to go.
DAYTIME RUNNING LIGHTS (headlights) should now be coming on when the key is in the “ON” position (whether you have the headlight switch turned ON or OFF). Foglights are still functional as described in the below mod.
Wow pretty easy huh! Hope this helps someone! Maybe you Canada?
----- Here are the Teg Tips instructions on the Fog switch mod. -----
The Generation 2 Integra Club and those posting these tips stress that performing these tips/tricks are at your own risk.
No one will be held liable for error / injury but yourself.
Rewiring Foglights.
The cool thing about this method is that you’ll wire the fog switch to another switch so that you won’t have to turn any lights on and cause your interior light (radio, clock) to dim during the day. You’ll be concerned only with the fogs switch and the rear defogger switch right next to it.
Disconnect the battery.
O.K., both switches will pop out towards you with a screw driver. The fog switch has five wires, the defogger has six.
First, find the red/yellow wire in the FOGS switch. Cut this wire about 2" away from the switch.
Now take the cut wire that’s STILL attached to the switch and splice it into the black/yellow wire of the Defogger switch.
You’re done. Now cover up everything with electrical tape including the other parts of the cut red/yellow wire of the fogs switch and see if everything works. The fogs should come on/off independently of the defogger switch which means you DON’T have to mess with the defogger switch ever. Just turn off/on the fogs button anytime and they WILL turn off automatically when the ignition is off.
Zaidoun
© G2IC.com 1997-2002. All Rights Reserved.
