Daytime Running Lights - Install!?
I know most Canucks don’t like having daytime runners on all the time, but it’s the law in canada…and if I’m to bring my car back, I’ll need to install them :frowning:
Here’s are my questions:
First, is there an easy/cheap way to get DRL’s installed in a 1990 US Teg? (need this to pass inspection)
Second, is it easy to disable? :wink:
Third, Is the relay interchangable between US and Cdn models? Ie: any chance I can just buy/borrow? the relay from somebody? :slight_smile:
Thanks,
~edcura~
Are you sure you really need them to pass the inspection?? Damn, just rewire you foglights and tell them they are your DRL’s! :evil:
uumm as far as I know DRL’s weren’t a manditory thing until '91 in Canada?
thats how I got away with disableing mine for so long and the cops couldn’t do anything about it.
Acura added a drl function in '90 as a saftey thing in Canada. In the '90s all the drl’s are is the parking lights come on when you put the e-brake down. '91-'93 the highbeams come on at a lower wattage then normal.
yup, Gigarange is right… My 90 only had the parking lights coming ON as DRLs… (I didn’t remember cause I disabled them a long while ago!)
Hmm, rewiring the fogs sounds like a good idea… :wink:
Sweet…
As for the actual rule. I read that all cars manufactured after Nov 89 are required by the government.
I guess the inspection will depend on how tight the mechanic is and how much he/she knows.
Rewiring the fogs sounds even better now…better check the teg to see how much damage I can do… :wink:
Thanks,
ed
