Hey guys, I’m in canada just to get that clear haha…
short:
My daytime running lights function, but not when I turn on my car.
longer:
I want to get them to work without having to turn my light switch at all…
currentlly, they only work when: I use my command start, and when I switch my light switch into the middle (off, middle, lights). I don’t know where the module is, I’ve searched and saw someone say that there is a module under the passenger side kicker… I couldn’t find that. I am under the influence that the previous owner did something to make these not work, its not the fuse, since I’ve checked that, does anybody have a picture of where the module is, and what I should look for? or at least a diagram, or an explanation of what to do? Thanks
probably removed it, and I don’t know where the wires would be located… the guys before me were heavy ricers, and did a bunch of crap that was un necessary, especially since I live in winnipeg, where most of this shit is pretty good to keep around… Under the trim, do you mean on the very right side that ‘touches’ the door
k cool thanks, thats what I figured, when I looked I faintlly saw a connection missing, that I couldn’t reach, figured that might be it, but it was also tucked pretty far back down, I guess I’ll try to see if there is a relay down there somewhere with 1 connector on there, as I understand if you take out the entire relay, something stops working, or your parking brake light is always on, not sure what it is lol
