so, I installed the harness everything was plug and play. I put in all necessary fuses and I tried the driver and passenger window… my power locks work…so that should say my harness was installed correctly right? well heres my problem my windows dont wanna roll up and down. suggestions? Thanks it’d be greatly appreciated.
did you add the window relay to the fuse box?
Yeah, the window relay is the redish/orange box right? I have it. By asking if I added it, do you mean did I clip it in? I think I did that. I’ll try get pics today to show what I have so far.
The relay clips on the fuse box i will look tonight an try to tell you were for sure
This is what i came up with
blown fuse #16 a 20 amp fuse in dash fuse box
power window relay…the relay is on the right side of fuse box above the big 40 amp fuse an below the fog light relay an the power window relay plugs in to the fuse box no wires plug in to it
poor ground
Hope this helps
alright so heres the new scenario. I got the relay finally haha I got confused with the power lock relay and the p/w relays. Well, I put the P/w relay in and I got full power to my driver side door and power locks. When I put my key to second click I hear my seatbelt beeping. but I plugged in the harness to my passenger and the power lock lags as if its not getting power and the window doesn’t roll up and down. same goes for the passenger rear. also, there is no more beeping for some reason. any ideas?
do you have the master window switch on lock so the other switches dont work?
