db2 shaking! need help!
so recently my driver side started shaking and steering wheel shakes badd…it only happens when i hit bumps or making a left turn…its not gotten worse wheel shakes violently and need to fix it…so far ive put new axles, changed my wheels new driver side mount…what should i check next…tie rods? wheel bearing?
Mine did this too. But at 3-4k Rpms and above…I changed my axle and made sure to tighten it up good…what it was…was a bad remanufactured drive axle…
how’s your driver side strut? mine was blown so it had the same effect. i changed it and problem fixed!
Try taking off your wheel, and see if your rotor wobbles at all…if so tighten up that big ol axle nut, and make sure u get a chisel or sumthn and tap the thin part of it. Im sure you know that, but some people dont lol. happened wen i got my car, felt like horribly warped rotors…but it was just that nut lol.
