[ATTACH=JSON]{“data-align”:“none”,“data-size”:“medium”,“data-attachmentid”:1117530}[/ATTACH] Incase anyone is wondering…
DCSPORT doesnt have one for DA. I use the one from DC/EG. Direct bolt on. Holes line up. Top Clearance is on point too.
EDIT:
The under hood fuse box wil be on the way. Either cut part of the sway bar or move the fuse box a bit, you only need one bolt the hold the fuse box, the bolt. Close to the battery can be removed, the move the fuae box out of the way. [ATTACH=JSON]{“data-align”:“none”,“data-attachmentid”:“1117471”,“data-size”:“medium”}[/ATTACH][ATTACH=JSON]{“data-align”:“none”,“data-size”:“medium”,“data-attachmentid”:1117531}[/ATTACH]
I think other brand would fit too.
I have no ABS, not sure for the one with ABS.
If ever the clearance issue will be the thing thats on top of the throttle body(pictured). [ATTACH=JSON]{“alt”:“Click image for larger version Name: Capture+_2018-09-14-02-54-37.png Views: 1 Size: 663.9 KB ID: 1117493”,“data-align”:“none”,“data-attachmentid”:“1117493”,“data-size”:“small”}[/ATTACH]
Just my guess… I’m betting they don’t list it as fitting our G2, because of the underhood fuse panel. I see you don’t have yours bolted up in its spot. Did you move yours.?
