I have 14 inch steelies and was wondering if dc2 integra hubcaps would fit. I actually bought a set and was wondering how to put them on. I tried taking off the lug nuts and screwed it back on and still came off with very lite force. Do these not fit?
Are the new hubcaps you got design for 14 inch rims?
They are integra 14 inch hubcaps off of a dc2 integra. It looks like it fits but it doesn’t clip on to anything.
dude…u’re gonna have to get new lug nuts…honda has lug nuts with black plastic washers that holds the hubcap in place. most people are gonna recommend you to replace all the lugnuts but you can just get 8 and install 2 of the new lugnut w/ washers on each wheel installing them across from eachother(common sense)…thats wut i did. also…you might already have the existing lugnut…but not the washer, just check the picture below if ur lugnut looks exactly like it with the groove to hold the washer. im sure you can purchase it from Honda. the washers just pop in if you’re curious.
you can also ask a friend with honda hubcaps if they are willing to trade eight of there lug nuts for 8 of urs, that’s if they do have all 16+ lugnuts with the washers…of course!!!
Wow thanks alot. I would have never guessed that. Are Honda lug nuts the only ones that have these? So aftermarket ones won’t be able to be used? Thanks for the reply
hub caps are gay
im pretty sure aftermarket lugnuts won’t work.
You’re really not supposed to use aftermarket lug nuts with stock wheels anyways. Most aftermarket lug nuts have a tapered head made especially for aftermarket rims… and stock lug nuts have a ball type head made for stock wheels… just fyi.
