DC2 manual pedal assembly in DA???
so i was driving my friend’s DC2 and i noticed something… it was too easy to drive… i looked at the pedals and noticed that the brake pedal was much closer to the gas pedal… so i went to the DA and did see the difference…
does the DC2 pedals fit the DA’s… knowing that ALOT of honda parts are interchangable… :read:
ha! wondering the same. i hate how my gas pedal is like underneath the center console. :rofl:
so i went to the junk yard today… and i ran into a dc2 with manual pedal… when i took out the pedal assembly it was in two parts… clutch pedal then the brake and gas… if you have taken out your pedal assembly on a DA, it comes out as a unit… so wat else could we do???
going through hondapartsunlimited… i noticed a brake pedal that is much larger making it closer to the gas pedal… i was wondering is this the automatic brake pedal??? it looks like it would work
the pedal assembly in a da comes out as a unit. the clutch in a dc is hydraulic, right? if so, then you may run into an issue with the clutch assembly
im going to call the dealer monday morning and see if the sell item #25
I don’t think this’ll work…but I’m in to see
jackass
i should kick you in the nuts for asking questions like this. looks like im getting gemma back this sunday… woot woot!!! ill be in miami in a month bitch
